[插件] PowerSurfacing最具革新性的solidworks曲面插件1.2-1.4中文版 for sw2012-2014【PS...
 火... [复制链接]
红尘风 发表于 2017-1-9 16:25:39 | 显示全部楼层
不明角力
kani1933 发表于 2017-1-5 10:58:49 | 显示全部楼层
跟随发芽ishfafiaiefouofuaofu奥uol 上的vsde法俄双方
dansonleo 发表于 2016-12-14 15:36:24 | 显示全部楼层
我也下一个试试
ericchen 发表于 2016-11-24 22:43:53 | 显示全部楼层
非常感谢
David1989 发表于 2016-11-3 11:31:48 | 显示全部楼层
怎么激活
David1989 发表于 2016-11-3 11:25:11 | 显示全部楼层
过来看看~
ZHOULONG8 发表于 2016-10-31 19:43:19 | 显示全部楼层
DUOXIEFENGXIANG
ifif 发表于 2016-10-9 19:14:26 | 显示全部楼层
谢谢楼主 好东西
bxll9523 发表于 2016-10-8 10:33:00 | 显示全部楼层
liuzhu weiwu
syzqsz 发表于 2016-9-11 14:55:43 | 显示全部楼层
Cylinder Wrap Tube Solid allows you to wrap a solid tube around a cylinder using the following rules:
  • The wrapping routines use the end points of lines and curves in the construction of the box or geometry (construction or non-construction) in the sketch to determine the cylinders Height (length of the cylinder) and the Outside Diameter (OD). The width of the box in either X or Y axis is equal to the circumfer-ence of the cylinder.
  • The diameter and height of the cylinder will be determined by either the geometry in the sketch or the four construction lines which will force the size of the cylinder.
  • The geometry in the sketch may lay outside of the box and will be wrapped to the height and diameter of the cylinder as determined by the box.
  • A face may be extracted from a solid model to wrap a cylinder, the face will be parametric.
A cylinder box must be constructed in the sketch mode and a single line will be used as the center line of the tube. The cylinder box must be construction lines in the sketch.
Note: The Cylinder Wrap Tube can also make use of Law Curves to control the tube radius along the length of the tube. See the Law Curves section for more information regarding the construction and use of law curves.
GMT+8, 2026-3-28 21:13
