CAD2012安装教程
当男人恋爱时 发表于 2017-2-7 15:11:55 | 显示全部楼层 |阅读模式
1.Install Autodesk Autocad 2012
  首先安装CAD2012
2.Use as Serial 666-69696969, 667-98989898, 400-45454545 .. or anything matching those templates
  选择以上任何一个注册码
3.Use as Product Key 001D1
  密匙  001D1
4.Finish the installation & restart Autodesk Product
  结束安装,然后重启计算机打开,再打开CAD2012
5.Before clicking on Activate
  You have 2 options :
   - a) Disable Your network Card, pull the network cable out or block with firewall
     (this is just to disable online serial check)
OR
   - b) Click on Activate and it will tell you that your serial is wrong, simply click
     on close et click on activate again.
Choose option a or b.
在你注册前你有两个选项,不过不要管,任选一个
6. Select I have an activation code from Autodesk
   选择我有一个注册码
7.Once at the activation screen:
  start XFORCE Keygen 32bits version if you are installing a 32bits application and
  64bits if you are installing a 64bits application.
  打开,32位或64位注册机
8.Click on Mem Patch (you should see successfully patched)
  在打开CAD2012的情况下,点击【Mem Patch】
9.Copy the request code into the keygen and press generate
  复制申请码到 【keygen】也就是上一个输入框,在点击【generate】
10.Now copy the activation code back to the activation screen and click Next
  You have a fully registered autodesk product
  复制得到的一组代码到CAD2012中,现在你就可以畅享CAD2012了,哈哈!
Songer
http://songertoy.com
NB:
1.Make sure you are running the Keygen as administrator and with UAC off on Vista or Windows7
  but you have to anyway to install Adesk products.
参与人数 1银币 +5 收起 理由
正树 + 5 赞一个!
GMT+8, 2026-3-26 01:38
